One thing you might look at is that the CD logic draws almost no current on the inputs and the regulators have big caps on them with nothing to bleed them off. You could add a resistor to ground to each regulator to discharge them. Maybe 100 ohms or so should do.This is my circuit.
When the side lights are off. So are the Orange LED markers.
When the side lights are on. So are the Orange LED markers.
When the side lights are off, and then the indicator is on, then the appropriate side Orange LED marker flashes in time with the Indicator until indicating is cancelled and then returns to the off state.
When the side lights are on, and then the indicator is on too, then the side light request to the appropriate Orange LED is overridden by the indicator request, causing it to flash in time with the Indicator until indicating is cancelled, and then returns to the on state.
The pulse converters seem to be the only parts of the circuitry which are working. The 4011 element of the circuit(s) only seem to work with this one rogue chip, as described above....!? why? I need help to fix this. Please.
Edit:
Sorry, wrong circuit. Add a 1K resistor from pin 1 to ground so it will be ground when the transistor is off.
