Cascade bjt and fet combination
Jony130
Joined Feb 17, 2009
5,601
I'll give you a tip.
At the beginning try to draw the small-signal diagram in exactly the same way as you have drawn the DC equivalent circuit.
Jony130
Joined Feb 17, 2009
5,601
No, simply drawn the amplifier as shown in the first figure and then replace the transistors with small-signal equivalent circuits.
Jony130
Joined Feb 17, 2009
5,601
Look here
As you can see I remove the transistor symbols from the schematic. Now all you need to do is to replace the transistors by using their small-signal equivalent circuit (pi -model).
Can yo do it ?
Jony130
Joined Feb 17, 2009
5,601
Very Good, but you forgot about C2 capacitor. C2 will act as a "short circuit" hence you need to add this "short circuit" into your schematic. And after that, you should see how simple the circuit becomes.
Yuvaloh1
Joined May 3, 2018
30
Wait a second..c2 will act as a short circuit and it 'shut down' the bjt amplifier with re resistor.it suppose to vanish?
Yuvaloh1
Joined May 3, 2018
30
First of all i think that r3 is shorted too.what is left r1 r2 in parallel.now in order do find voltage gain in term of the drain resistor voltage plus transconductance.now if vout=gm*vgs*rd
Yhen vin is I*Rin but in order to vanish the vgs term in the numerator i need that vgs will conclude in the vin term.so how i add the Rin to the buisness.understand?
