Cascade Amplifier
JeromeDarshana
Joined Sep 17, 2010
11
hi i need to make an amplifier which has
gain of 15
output impedence of 30 Ohm
input Impedence of 30 kOhm
this must be a cascade amplifier.
can some one explain how to do the calculations ??
i need all the formulas and the was how they determine :)
Audioguru
Joined Dec 20, 2007
11,248
Did you look at the cascade amplifiers in Google?
They are simply one amplifier that is amplified by another amplifier.
The gain is only 15 so it should be easy. The first stage can be a common-emitter transistor.
The output impedance is very low so it should have an emitter-follower or a pair of complementary (NPN and PNP) emitter-followers as the second stage.
The input impedance is fairly high at 30k so the first transistor should have a fairly low current and an emitter resistor to increase the input impedance and reduce the gain.
