Capacitor selection for 3.3V buck converter.
DickCappels
Joined Aug 21, 2008
10,661
220 uf should get you 50 mv or less of ripple. If you cant even less, use more capacitance. With a 3 am load, use a low equivalent series resistance (ESR) capacitor.
You may need to put a few in parallel to get the ESR and therefore ripple down to an acceptable level.
Ian0
Joined Aug 7, 2020
13,317
10uF multilayer ceramic seems to be popular, used in multiples for larger output currents.
You will also need some smaller ceramic caps in parallel to deal with the higher frequencies.
Qodvux
Joined Aug 1, 2023
I was wondering if there were equations that would allow for choosing capacitors for different input voltages. For example the 12 Vdc input is going to come from half wave rectified 24 Vac. So, I think that Cin should be bigger to account for the varying input voltage, but I don't know by how much. Are these things usually figured out experimentally?
