first of all, i want to say i am a big noob in eletronics, i learn my best in the internet and try to apply it in real world, i have had nasty experience of going into pratical without knowing the theory first in eletronics, and i paid the price burning my hand. So i quite want to have the theory first before even thinking to do anything.
ok, so, i have a 80 watt solar panel, and i want to drive 2 eletric DC Linear actuators, to move a heavy thing. details on this is not necessary as for i need help is in the capacitors.
so each motor is as estimated a low RPM DC motor with high torque, which these ones give out around 1200N of force in the mechanical geared actuator. these two motors consume 3 amps, at a voltage of 12V. multiplying it gives 36W each, so both would consume 72 watts when operating at the same time. Besides this, i also have an arduino, a 4 channel relay, and a few LDRs and switches. and a 4A thermoeletric Peltier module, with a heat sensor, and other sensors too, i have an arduino Uno, i am thinking in getting a multiplexer for the analog inputs but it seems very complicated, i think i will aquire a Arduino Mega. (Sainsmart has a cheap and very good one).
for the record, i am studying renewable energies.
and by far when you grabbed your mental calculator, you pretty much see the solar panel i have wont suffice for my needs right?
yep, that's when the Capacitor banks i read so much about, and saw so many videos about, even a rail gun.
so, i know so far that the capacitors have a very different use from a battery, like for one of those dozens of videos i saw, i can actually turn a small AC current into a DC current using just capacitors and a few diodes.
so, the idea of replacing a large battery here, is to prevent a deep charge or use of expensive controllers to take care of the batteries, and also the actuators wont be constantly running. they are for positioning accurately, so i dont need to run them constantly. only a few times per hour. making the calculations, without the two motors running at the same time it will give me around 55 to 65 watts of usage. and i forgot, i will use 2 small Dc water pumps, like those in aquariums. so i have then 15 watts of energy left for use. what i have now is a car baterry and its not fullfiling my needs.
so this is my idea:
to have a capacitor bank, that can power 72 watts of both motors for around 10 minutes. and be recharged fast with the 15 watts i have left to use from power from the solar panel, and then, capable of powering a single arduino in sleep mode, for 36 hours.
i heard avout the super capacitors and ultra capacitors, i went to check some prices, and well... my budget is not that big. so as cheap as possible is what i'm aiming at. Also capacitor bank volumes is not a problem. not weight.
can you please help me out in a capacitor bank that suits my needs?
How many Farads i would need? in parallel? or in series?
and thank you so much for taking your precious time to read this. i really apreciate it alot. and if help me, even more!
i'm just another DIY-er with super enthusiasm both in renewable energies and eletronics, although picked eletronics road,
as my family used to say, " a road is just one lane, a highway has more lanes". pretty inspiring to me to get into the multitasking world too. will you help me slowly getting into the eletronics world with this?
so this is my idea:
