Capacitor Doubt
imraneesa
Joined Dec 18, 2014
227
  • Input voltage: 2.6V to 10V Max (Limited by input capacitor)
  • Output voltage: 1.25V to 10V (Limited by output capacitor)
I saw this in some webpage. that is regarding the laser diode driver.
my question is how can we limit the output using capacitor and what is the formula for that.
if my input is 7.4v and I want the output to be 3.5v how can I limit it using capacitor on the output.
imraneesa
Joined Dec 18, 2014
227
he did not give any schematic. he is just selling linear drivers using LM1085. in that he told the output is 1.25v to 10v (limited by output capacitor).
so capacitor will not limit the voltage right?
imraneesa
Joined Dec 18, 2014
227
LM1084 based linear driver: $8 shipped CONUS! (INTL available at extra cost)
  • Low drop out (~0.8V)
  • Input voltage: 2.6V to 10V (Limited by input capacitor)
  • Output voltage: 1.2V to 10V (Limited by output capacitor)
  • Output current: 50mA to 2000mA (5A max)
  • 2 x lithium ion batteries recommended
  • Outputs over 1A heat sink is a must! Both IC and resistors!
  • Dimensions (11mm x 17mm)
  • Continuous ground
Capacitors do not limit the voltage.
Show us the schematic you are talking about.
bertus
Joined Apr 5, 2008
22,922
The LM1084 is a voltage regulator.
I assume the laser diode would need constant current, wich the LM1084 will not deliver.
Do you have more details?
bertus
Joined Apr 5, 2008
22,922
In that schematic the LM is connected as constant current source.
I have a schematic from the LM317 datasheet:
imraneesa
Joined Dec 18, 2014
227
ok so capacitor has nothing to do with the limiting. I know about that. but just was in doubt when I saw those statements. so I thought to clarify it here. thank you so much friends. I am looking for 1.8A driver with less heat sink. if you have any good ic's for this purpose please let me know.
18,104
The limits referred to may have been a result of the voltage rating of the input and output capacitors. Just a guess.
