Cap id
AlbertHall
Joined Jun 4, 2014
12,653
Without a schematic I'm afraid the only possible answer is maybe.
They are not expensive so you should get a correct replacement. Note that both of these capacitors are class X2 (suitable for permanent connection across the AC supply) and any replacement should be X2 as well.
spike1947
Joined Feb 4, 2016
537
It is from a Flymo Hover Mower
Ya’akov
Joined Jan 27, 2019
10,322
In the handle, across the push button switch
That capacitor is there for arc suppression. When the switch is released, the cap charges up and prevents an arc across the switch contacts. I am not sure .15 will be sufficient, but if not the only "danger" is wearing out the switch faster.
Apparently Flymo spares for the switch and cap are readily available.
