Cant identify Resistor color code
Nelson2001
Joined Nov 10, 2011
27
I reparing a power supply (thermaltake PFC control), high end psu. In the mobo i found this set of resistor but can`t identify colors.
, so her values. They are in the primary side of the PSU.
I google it, i think they are fuses, or inductances but not!.
Dodgydave
Joined Jun 22, 2012
11,395
I would say the top and bottom ones are inductors as they have spiral wire wrapped around the body, the middle one maybe 0.1 ohms, but if they all read 0.4 ohms then they're all inductors. You need an inductance meter or dvm with built-in range,
Best guess top to bottom...
8.2uH
11.8mH
7.5mH
ian field
Joined Oct 27, 2012
6,536
You cAn help me?. Thank you in advance!View attachment 91682
They look a lot like wire wound power resistors to me.
Normally anything with a gold multiplier band would be less than 10R, and anything with a silver multiplier would be less than 1R - but I wouldn't discount the possibility of close tolerance resistors with an extra colour band. An extra band is an extra digit so the value would be 10x more than a quick glance at the multiplier band suggests.
Some DMMs are not capable of resolving anything under 1R, so the values quoted aren't too surprising.
The favourite method of measuring very low resistances is to build a constant current source and calibrate it - if you know the exact current you pass through a resistor; the volt drop will allow you to calculate the resistance.
18,106
Ditto. My money is on low ohms resistors, maybe used as current shunts in the PCB.
On the other hand, that one in the middle with a silver band in the middle is perplexing. I'm not aware of any resistor code that would put a silver band in the #3 band position.
And now that I think about it, black isn't a valid color for the 5th band (top part), either. Maybe I'm talking myself away from resistors.
ian field
Joined Oct 27, 2012
6,536
The band(s) at the other end probably do more than just the tolerance.
There doesn't seem to be any set in stone standard, an extra band there can indicate magnitude of temperature coefficient, or just that its "high stability".
be80be
Joined Jul 5, 2008
2,395
Buy a banggood transtor tester it really a parts tester but it can test inductors and capacitors resistors diodes and of course transistors
GopherT
Joined Nov 23, 2012
8,009
Thank You all, I take a few more pictures, from the mobo and I see clearly R printed in it.
Don't know how it works. May be jus like fuses?
They are low ohm resistors. If your. Ever has a RELATIVE function, short the test leads together to measure resistance of the leads and connections. Then press relative to zero and measure the resistance. They are likely current sensing resistors, low and very low ohms.
