Cant get zero rise time in LT spice?
MikeJacobs
Joined Dec 7, 2019
232
So I know such a thing doesn't exist, but for the purpose of testing something else, I need to get a pulse out of a voltage source that has essentially zero rise time.
I am finding that leaving the rise and fall time on a pulse voltage source give me 10ms rise and fall no matter what I do?
How do I get a pure 0 rise time pulse in lt spice?
Thanks all
MikeJacobs
Joined Dec 7, 2019
232
ok well please disregard!
This is one of those posts that I found the answer like 5 seconds after I posted it. Sorry
Apparently leaving it blank defaults to 10ms.
putting something like .0000000001 in sure did the trick.
Thank you!
eetech00
Joined Jun 8, 2013
4,724
Thanks all
Hi
LTspice is doing what it should.
Any "pulse" has rise time. LTspice faithfully honors that in the time domain.
eT
Papabravo
Joined Feb 24, 2006
22,112
The reason why LTspice cannot deal with a zero rise time is because the unit step is discontinuous at the origin and the derivative does not have a defined value at the discontinuity.
ebeowulf17
Joined Aug 12, 2014
3,307
Thank you!
Not that it really matters either way, but you can use the abbreviations for prefixes like milli and micro. So, instead of all those zeroes, you can put 1u, 100n, etc.
38,703
I believe the default pulse rise and fall time is something like 10% of the pulse period (and zero rise time is not possible, either in simulation or a real circuit)
But you can specify 1ps (picosecond) or less if you like.
MikeJacobs
Joined Dec 7, 2019
232
Ah yes, forgot about that!
Been a long time since I worked on that kinda stuff.
Thanks all. seriously good people here
Papabravo
Joined Feb 24, 2006
22,112
Interestingly I just discovered with respect to diode breakdown models there is a provision for a quadratic fit in the breakdown region. These guys who came up with this stuff were...quite forward thinking.
