Candle Wick Lighter
gyue
Joined Jun 6, 2024
18
We have a project that requires us to light up a candle using electronics. My plan is to short a 3.7 V 2200mAh battery and a wire looped into the candle wick. how should I go with it ensuring my safety and others. How can I add a switch without the switch breaking due to heat?
KeithWalker
Joined Jul 10, 2017
3,619
That is not a good idea. You will probably exceed the maximum burst rating for the Li-Po and could cause an explosion and fire. Check the data sheet for the battery you are using. There is a maximum safe current you can draw that will not damage the battery. What ever you decide to use as a heating element, it must draw less current than that.
Ian0
Joined Aug 7, 2020
13,279
You need to direct the explosion and fire on to the candle wick. Then you've done it!
HarryA
Joined Sep 21, 2024
Put a match on a servo, when the match rotates it contacts a piece of sand paper.
Then the lit match lights the candle.
KeithWalker
Joined Jul 10, 2017
3,619
connect a piece of insulated 16 AWG copper wire to each pole of the battery. Connect your heating coil between the ends of the wires, similar to how a solder gun is made.
Backyard
Joined Oct 15, 2024
16
A light bulb with the glass will be a one time quick action candle whick lighter. But a bulb/heating element and battery doesn't strike me as "electronics". Just electrical
I'm thinking you're going to have to come up with a high voltage arc to light the whick. Maybe something simple like a relay wired to buzz and a voltage multiplayer until it's high enough to create a small spark.
Or a full fledged oscillator with a step up or flyback transformer not too unlike a stun gun
It might be helpful to know if the requirement is it has to be "electronic" or just electrical
