Can we use this circuit to prevent going flyback to supply line?
booboo
Joined Apr 25, 2015
168
Thanks but the spikes goes to the supply rail when we turned off the solenoid and it would disturb some-things.
DGElder
Joined Apr 3, 2016
351
Don't know your switching speeds but a schotky diode may help if your diode isn't fast enough. And or consider an RC or diode RC snubber network.
38,912
No. The top diode would make the lower diode useless in killing back-emf spikes.
Don't know why you say that Alec. :confused:
The top diode will not affect the operation of the diode across the relay coil, whose purpose is to conduct the inductive coil current when the transistor turns off until the inductive energy is dissipated.
But the transient from the relay coil inductance when the relay is turned off is slightly negative at that point and small (one diode drop), so I don't see how that could cause a significant problem in your system. A decoupling capacitor from the power to ground at the relay connection point should take care of that.
How long is the wire between the relay coil and the transistor collector?
What value of spike are you measuring on the rail, or is this a theoretical concern?
38,912
Don't know your switching speeds but a schotky diode may help if your diode isn't fast enough. ..............
The turn-on time of a normal silicon junction diode is very fast, which is what is needed for this application
Their turn-off can exhibit a long reverse-recovery time, which a Schottky doesn't have, but that's not an important characteristic for a diode use for transient protection across an inductance.
DGElder
Joined Apr 3, 2016
351
I wasn't thinking, its not like you are going to be switching relays in nanoseconds.
38,912
Of course not.
But the diode has to start conducting as fast as the transistor is turning off to minimize any voltage spike from that turn off.
In other words as the transistor is stopping its carrying of the coil current, the diode has to take over carrying that current until the inductive energy has dissipated.
