Hello all and thanks for any help I have a bit of a problem with a Logicdata controller
first i will explain what is happening i have 4 switches connected up to the controller with on-board LED's the controller is waiting for an input of 5v witch comes from the controller my issue is that when i program the controller per manufactures instructions i start getting noise on there 5v line the LED's start to flicker every 16 seconds I know this is a problem with the controller my thoughts are it is sending a signal to get information from the motor encoder witch it should not and I have contacted the manufacture about this fault still waiting for a reply 6 days later and i need to get this project done in a week .it did not do it when it was UN-programmed
so that brings me to my point I am thinking of adding a second psu for the switches at 5v dc and using a mosfet to bypass the dirty controller signal to stop the flickering both use 5v yet the controller drops every 16 seconds to <3v (as far as I can read using a multi meter )witch turns the switch LED's off i need to know if this will work I cannot open the controller as it will void warranty the controller has a max input of 5v 250ma will this be a problem if I use a 5v 1a power supply will I even need a mosfet .The switches output whatever is put into them, or is there another way i do not know
any help will be most appreciated and thank you in advance
