Can I use a AC 250V 1A rocker switch for a 5V 4A DC project?
Bassquake
Joined Feb 16, 2018
97
As title really.
Wondering if ok to use a rocker switch that specifies AC 250V 1A for a 5V 4A power supply plug? It's for a usb hub.
OBW0549
Joined Mar 2, 2015
3,565
I wouldn't do it. Aside from the issue of severely overloading the contacts with 4X their rated current, there's the issue of contact resistance and voltage drop: running on only 5 volts, your application is likely going to be VERY sensitive to any voltage drop across the contacts-- and that voltage drop is likely to be very substantial due to the high current.
Buy a proper switch meant for low-voltage, high-current service.
And don't get it from Ebay.
Bassquake
Joined Feb 16, 2018
97
Ok will do. Any in particular you recommend?
dl324
Joined Mar 30, 2015
18,490
You need to consult the datasheet.
I looked at a datasheet for D4 Cherry switches. They only gave a DC rating for the last one:
And the DC current capability was lower.
This is from C&K:
28,488
What is not mentioned is if the switch is in the mains power to that 5 volt supply, or if you are wanting to switch the 5 volts line. There is a very big difference. It should be OK switching the mains power, not the 5 volts line.
Bassquake
Joined Feb 16, 2018
97
It was for the 5v line. Have selected a 6A inline rocker switch now. Thanks all.
28,488
It is quite unusual to switch the DC power line for a hub. Why do it? That is a puzzle to me. Generally the hub stays on with the computer serving it.
Bassquake
Joined Feb 16, 2018
97
I put a switch on the hubs psu as it was drawing 2 watts even without anything plugged in to the usb ports, compared to 0.1 watts when PSUs switch is off so it's to save electricity (I'm on a meter)!
The hub uses the pc for low power stuff like flash drives or ssds. If I need to plug in a mechanical drive, I can just flip switch to provide more power.
