Can anyone figure out how this polarization circuit keeps at fixed voltage an input pin
Houseman
Joined Sep 25, 2018
22
Hi forum.
During the reverse engineering of a constant current small LED circuit driven by an IC I run into this "strange" schematic that I attach.
The IC (Infineon's IL6150) is a monolitic LED driver that has an internal PWM generator driven by an analog or digital voltage applied to PIN 2.
The input pin has an internal pull-up circuit to high level if not connected externally on PCB. Icc,PWM current is approx. -18uA
Driving it via a 0 to 4.5V analog voltage changes the PWM according to this table:
So on the PCB there is a polarization circuit I have simulated in LTSpice here:
Two Common emitter NPN in series that should keep PIN2 IC voltage above 4.5V.
Note that this transistor has two internal series biasing resistor (R4,R5 and R6,R7) at the base and the emitter of 47k I needed to insert in the simulation otherwise they gave not the same voltages as measured.
Following logic, Q1 is on, in saturation mode, since V at nod R4,R2 is 4,5V so Q2 should be off.
No external polarization from the collector, so Q2 is off.
Vpin2 has been measured to be 8mV, no current flows out of Q2 collector, pin2 is held high by its internal circuitry.
So Why the heck did you need to implement this external biasing circuitry??
The designer should have something in mind I do not recognize, either because I am missing something or I am wrong in my consideration.
* First of all are my considerations right?
If the designer would have wanted to maybe change and keep at fixed PWM by changing the Vpin2 from 0 to 2.5V according to the datasheet and the PWM dutycycle, what kind of resistor should he have to change?
* Am I correct if I say, I need to turn on Q2 by letting Q1 return into linear mode?
Howto acheive the 0-2.5V voltage range?
Any suggestion howto make such a variable voltage 0-2,5 by a trimpot?
Best regards and thanks
Ian0
Joined Aug 7, 2020
13,286
Wouldn't that be driven by pin 7, with no connection to pin 2?
I'm assuming that the SPICE voltage source Vin is the supply voltage (might be wrong) so that would be connected across pins 4 and 7. If the voltage between pins 4 and 7 is too low, it shorts pin 2 to ground disabling the output.
Papabravo
Joined Feb 24, 2006
22,113
Hi forum.
I think your simulation needs to include the pullup arrangement inside the IC consisting of the current source and the Zener diode. Otherwise, the voltage at the collector of Q2 will be GND or undefined. As it stands it is an open collector output.
Houseman
Joined Sep 25, 2018
22
I think you nailed it, except for the precise behavior of the pullup inside the Infineon chip. Nice job. Still, it would be nice to know the Zener voltage of the diode inside that chip.
Probably it's 5,5V in order to keep overvoltage protection to the digital input pin (that as specs says it admits voltages up to 5,5V) in case of someone puts Vs = 40 V into that.
Houseman
Joined Sep 25, 2018
22
Supposing a Vs voltage of 12V (as it is) the behaviour of pin 2 is strange. why is measured voltage 4,5V and simulation shows 0,8V...
Papabravo
Joined Feb 24, 2006
22,113
Maybe because your diode is not a Zener diode.
Q: What is the reason for making Vin a linear ramp from 0 to +12V and repeating that action?
Papabravo
Joined Feb 24, 2006
22,113
Here is what I get for this circuit. A 1N750 is a 4.7V Zener. I just guessed a value that was available. It struck me that V(vz) does not need to be a constant, but it CAN be the average of a periodic waveform. It can certainly be ≈ 2.344 Volts.
eetech00
Joined Jun 8, 2013
4,727
Hi forum.
What is the external circuitry intended to accomplish?
If nothing is connected to the PWM pin, then the pin will be pulled up to 4.7v internally, so LED PWM would be %100 duty cycle at a fixed freq 1.6 kHz. If you want to fix the duty cycle at some lower percentage, then do the math, and add a voltage dropping resistor from PWM to ground to drop the DC voltage to the desired level below 2.43v. You can do the same using a trimpot to make the duty cycle variable. The internal zener (probably 5.6v) at the PWM pin provides some over voltage protection as the device can be damaged if the PWM pin voltage exceeds 5.5v
At least thats how I think the pin works per the data sheet.
Papabravo
Joined Feb 24, 2006
22,113
There is still a great deal we do not know about this circuit and how it was intended to work. It is unusual to see a transistor circuit that is working from a sawtooth voltage source. Since this is a simulation component it might be interesting to know how the circuit is built on the actual board.
Houseman
Joined Sep 25, 2018
22
I was simply investigating how the Q2 NPN was acting to see if it was going into different regions, but no, the NPN simply never turns on..
So Vin = Vs = 12V already
Houseman
Joined Sep 25, 2018
22
Nope the transistor is powered by Vin voltage (in my case 12V). It is built in the way I have built a simulation.
Here You have the photo of the actual PCB
Papabravo
Joined Feb 24, 2006
22,113
I was able to make it turn ON so it appears to be possible. When it turns on it sets pin to almost GND which does not make much sense. So it looks like we are back to square #1
