can a tvs clamping voltage damage mosfet gate
bertus
Joined Apr 5, 2008
22,994
There are absolute maximum values given in the datasheet of mosfets for the Vgs voltage.
Going over this value, the mosfet will likely not survive.
Post a schematic with all the details.
Bertus
dl324
Joined Mar 30, 2015
18,453
is the mosfet gate damaged if it clamps to ~40% more than Vgs rating?
Most likely.
transients are typically short.
Any allowable overstress from transients will be listed in the datasheet. If it isn't, then you should assume that it isn't allowed; or contact manufacturer to see if it's characterized.
