Same response ... Yes, No, Maybe ...Could it detect a 1 nanowatt signal or would that be too small?
You can:How do i build a receiver that has the required sensitivity?
Easily today with modern technology. The Deep Space Network is receiving signals in the range of a fraction of a femtowatt. DSN's 34-meter antennas can detect signals as weak as -160 dBm. That's like 2.2e-9 into a 50 ohm load.So it is possible to build a receiver with a sensitivity of 1 microvolt?
Sure you could.Can you build a receiver with a sensitivity of 1 nanowatt at home?
I have used that part and it is good to 2uV on FM. Not 1nW.Sure you could.
Where did this number come from?Can a monopole antenna detect a 1 microwatt signal?
This is 1/1000 of the power. Where did this number come from?Could it detect a 1 nanowatt signal or would that be too small?
yesSo it is possible to build a receiver with a sensitivity of 1 microvolt?
noCan you build a receiver with a sensitivity of 1 nanowatt at home?
I know, it's just a example for the OP as a simple receiver type. Still it's unlikely the OP will build anything. Good GPS chips today (using pseudonoise codes to detect signals below the noise level) are much better than that FM receiver chip.I have used that part and it is good to 2uV on FM. Not 1nW.
Acquisition sensitivity represents the minimum power level at which a GNSS receiver can achieve a position fix. This is the minimum level to successfully perform TTFF under cold start. Cold Start is the TTFF condition where the GNSS receiver has no information about the satellites above. It needs to conduct a full search of the sky to find the satellites in view and obtain the almanac and ephermal data. Acquisition sensitivity is usually around -140 to -150 dBm.
What is the budget for this project? LOLcrygenic cooling of input semiconductors
I think he means (judging from previous conversations with the poster), one's that don't require cryogenic cooling.What is the budget for this project? LOL
| Thread starter | Similar threads | Forum | Replies | Date |
| H | Need help to design an array antenna | Wireless & RF Design | 1 | |
Patch antenna phased array | Wireless & RF Design | 8 | |
| B | Antenna SWR | General Electronics Chat | 2 | |
Broken U.FL / IPEX antenna cable connector on Meta Quest 2 controller – repair options? | Technical Repair | 0 |
