Can 74LS76s be interconnected with 74LS73s? Also Questions on doing a BCD Down Counter from 24 to 0
Boreal Knight
Joined Feb 18, 2017
10
So for some reason, my 74LS73 ICs burned out or malfunctioned while doing the switch part in this circuit. (Around the START/PAUSE)
I opted to use a 74LS76 IC with the Preset and Reset set to Vcc while I build the expression written on the picture. So far the down counter worked however the 5th bit (still used a spare 73 on the last one) never goes into low voltage or doesnt turn off. The Reset of that 73 is set to Vcc and the J/K inputs are set as shown above. Also, how do I build the switch that controls the START/PAUSE without making my 76 malfunction permanently? The last time I built it was
Clock Above Dip Switch
Wire Below the Dip switch connected to the AND gate and the output is connected to the main clock of the circuit.
Should a part of the dip switch be grounded or something?
Also, after I build the reset OR Gate with the expression, should I manipulate Preset on the 76 or do I leave as is?
Alec_t
Joined Sep 17, 2013
15,149
So you've learned a valuable lesson : always read the datasheets of parts that you want to use. According to the datasheets for 74LS series ICs the absolute maximum supply voltage is 7V and the recommended value is 5V. Why are you using 9V?
dl324
Joined Mar 30, 2015
18,449
An easier to read, IMO, schematic with irrelevant information omitted:
I'm just going to get this out of the way... While certainly not the worst I've seen, definitely near the bottom. Unnecessary wire jogs and crossings, so much inconsistency.
When your switches are open, the inputs they're connected to float. What logic level to you get on a floating TTL input?
As pointed out, 9V exceeds the absolute maximum voltage rating for LS TTL and is sufficient to have destroyed or made your ICs unreliable. They should be discarded so they don't cause difficult to troubleshoot problems later.
Boreal Knight
Joined Feb 18, 2017
10
I
It's 5V in the actual. Forgot to change the diagram
Also to clarify, I did read the sheets and were working properly prior to connecting the reset expression
dl324
Joined Mar 30, 2015
18,449
There is no reason why connecting 5V to reset would damage components; unless something is not wired correctly.
If you want help troubleshooting your circuit, you should start with what you expect it to do and what it's actually doing.
T Homework Help 2
