CamBam / CAM help?
spinnaker
Joined Oct 29, 2009
7,830
OK with the help of @cmartinez and a few others, I was successfully able to CAD my drawing. Now it is time for the CAM part and I am a bit confused by some definitions.
There are few settings I need some confirmation on
Depth Increment Depth increment of each machining pass. Determines the number of passes to reach the final target depth.
Final Depth Increment The depth increment of the final machining pass.
Target Depth The Z coordinate of the final machining depth.
First and second one seem easy. So if I make my target depth 1.5mm and my depth increment .1 it will make 15 passes?
What is the purpose of Final Depth Increment? Does that allow me to make my final pass different from the other passes? Why would I want to do this?
cmartinez
Joined Jan 17, 2007
8,853
I'm not sure I understand either... but from what I gather, the Target Depth is the final, absolute depth of cut/machining that will be attained. The final depth increment would be the amount of material that would be removed on the tool's last pass.
tranzz4md
Joined Apr 10, 2015
315
Rough passes for greatest material removal don't typically leave a good final finish. Your CAM program will resolve "backward" from your finish pass depth. Surface speed (and/or tool speed) on your final pass can be varied too to achieve a good finish.
spinnaker
Joined Oct 29, 2009
7,830
So do I make the final pass deeper or more shallow than the others? And why?
tranzz4md
Joined Apr 10, 2015
315
Shallower. You are certainly familiar with the expression "blue chip". The surface speed is determined by the metal, alloy, tool, coolant and finish. The best removal rate will acquire a chip with a slight coloration change, and that is achieved by the depth of cut at correct surface speed. Your final pass must be deep enough to acquire a "clean chip" but not enough to get much coloration. How is this determined? My generation did it by careful adjustment during the cutting. I'm no toolmaker or small batch machinist, but was taught a bit by a couple great ones. I'm sure there's a good forum somewhere out there for just this sort of thing. I believe the charts in Machinery's Handbook may show a figure or multiplier and range.
cmartinez
Joined Jan 17, 2007
8,853
I agree with tranzz... the last cut has to be just deep enough to remove the markings done by the previous one, plus a little more material. In theory, you have to readjust rpms and feed speed to obtain optimal results, but in practice that is seldom done.
spinnaker
Joined Oct 29, 2009
7,830
I am cutting MDF on a cheap Chinese router / engraver.
Any recommendations on settings?
And another question. Mainly what I have on hand is engraving bits used for PCBs. I do have a few endmills. One about 2mm width. And I have a ball end mill maybe 1.5mm
Should I invest in some endmills? If so what size?
This is what I will be milling.
cmartinez
Joined Jan 17, 2007
8,853
For a piece like the one you're working on here, a two-flute 1/8" end mill oughta be enough... But I suggest you also buy 3/32" and 1/16" end mills, in case you need them later. Be careful who you buy them from. Always buy carbide (never HSS) and look around for a good price, you'll be surprised to see by how much it can vary.
spinnaker
Joined Oct 29, 2009
7,830
Any idea on where to get a good price? what is a good price?
I found these
https://www.ebay.com/itm/10Pcs-Doub...090343&hash=item4675550b47:g:EfsAAOSwYDZaVxMM
Is tungstan the same as hss?
spinnaker
Joined Oct 29, 2009
7,830
What is wrong with HSS?
cmartinez
Joined Jan 17, 2007
8,853
What about these?
https://www.ebay.com/itm/141863252431
I understand 2 flute is better for chip ejection but won't I have just dust with MDF or plastic?
So what do you think about the 4 flute that I posted above vs 2 flute?
For MDF, 2 flute is best. But you can perfectly work with 4 flute too, with a slower cutting speed. Otherwise the dust won't be ejected as efficiently and the finish might suffer a bit.
Those bits look good, and at a decent price too. It's worth buying a few and test them... The thing here is, that I suggest you buy at least one high-quality one with similar characteristics so that you may compare their performance. Only experience will tell you which bits are best for each particular purpose.
spinnaker
Joined Oct 29, 2009
7,830
Well Pretty much my only option is slow with my cheap machine. ;)
But I am guessing you mean the feed rate which I can get going pretty fast. My spindle speed is that one that is slow.
