Calculus-Maxima and Mininma
Breeze
Joined Jun 30, 2015
24
Good day to all of you Honorable Engineers,i am a bit lost with how to attempt this calculus problem,it goes like this "A mining company has 10 000 meters of fencing available.It wants to use the fencing to enclose a rectangular field.One side of the field is bordered by a river .If no fencing is placed on the side next to the river,what is the largest area that can be enclosed?
i assumed my width to be 'x',then divided the field into 3 parts to get the length as a function of width and got this expression: Length=(10 000-3x)/2,but this is where i get lost because the other side of the field that borders the river will not be fenced ,so how can i then derive my equation without the other side being fenced?
33,021
Draw a sketch of the rectangular field. Because it is rectangular, what do you know about the relationships between the lengths of the four sides.
Taking into account that one side is bounded by the river, what is the perimeter of the field as a function of the variables that describe the lengths of the sides?
What is the area of the field as a function of the variables that describe the lengths of the sides?
What constraint does the amount of finding available place on the relationship between the variables that describe the lengths of the sides?
What is the area of the field as a function of the amount of fencing available and the length of the side bounded by the river?
How do you find the length of the side that is bounded by the river that maximum the areas enclosed?
Russmax
Joined Sep 3, 2015
82
Yes, Breeze, your way sets the ratio of W & L before you begin. The point of your calculations will be to find the W/L ratio that yields maximum area for a given (partial) perimeter, so you'd have to be a lucky person to get the right answer.
This is really the same problem as if you were fencing all sides of the field, you just have to make an adjustment to your perimeter equation.
Breeze
Joined Jun 30, 2015
24
Breeze
Joined Jun 30, 2015
24
Good morning Senior Engineers-I want to express my gratitude at all your hints you gave me,i did manage to solve it-I got the equation to be (2w+L=10 000) then i solved for L in this equation and substituted that result in the equation for Area..
33,021
So what is the largest area that can be enclosed? How do you know that it is the largest?
Reading between the lines, I think this part wasn't the problem for him. He was having problems seeing how to reduce the information to a single function of one variable that could then be optimized.
Breeze
Joined Jun 30, 2015
24
The largest Area is got by equating the first derivative (f'x)=0 to get a critical or turning point because we get the local maxima or minimum when the curve is equal to zero.
33,021
Correction: local maxima or minima when the slope of the curve is equal to zero.
