This is inspired by another, similar ongoing thread. You do not need to read and understand the entire premise and explanation, you can go to the end and read the question which is purely mathematical.
Some time ago I had to replace a hot plate of an electric cooking stove. The plate is just a round, enclosed part with four electric terminals. After doing some tests I suspect internally it has four resistors connected as a square (or diamond if you prefer) and the four terminals are the four corners. By connecting the full voltage of the mains in different ways to different corners the heating power can be regulated.
When I installed it I was curious about determining the values of the four individual elements but I soon gave up. Note that I do not have access to the elements individually but that they are always connected inside the hot plate.
Draw a square and the four sides are the resistors, R1 at the top, R2 right, R3 bottom, R4 left. The four terminals are T1 at top left, T2 top right, T3 bottom left, T4 bottom right.
The power switch has six active positions plus a seventh OFF position. Let us call the two power cables L1 and L2.
Using | to mean parallel:
In position P1:
- L1 is applied to T1 and T3 and
- L2 is applied to T2 and T4.
This puts all four elements in parallel and applies the full voltage to them.
RP1 = R1 | R2 | R3 | R4
In position P2:
- L1 to T1 and T3
- L2 to T4
RP2 = R3 | R4
In position P3:
-L1 to T3
-L2 to T4
RP3 = R3 | (R1 + R2 + R4)
In position P4:
-L1 to T1
-L2 to T4
RP4 = R4 | (R1 + R2 + R3)
In position P5:
-L1 to T1
-L2 to T3 and T4
RP5 = R4 | (R1 + R2)
In position P6:
-L1 to T3
-L2 to T4 and T2
RP6 = R3 | R2
The Question:
How can we calculate R1, R2, R3, R4 as a function of RP1 to RP6?
We have six equations. Four should be enough and the other two should be in agreement and serve to confirm the results.
RP2 = R3 | R4
RP6 = R3 | R2
In position P1:
In position P2:
- L1 to T1 and T3
- L2 to T4
RP2 = R3 | R4
In position P3:
-L1 to T3
-L2 to T4
In position P4:
-L1 to T1
-L2 to T4
In position P5:
-L1 to T1
-L2 to T3 and T4
In position P6:
-L1 to T3
-L2 to T4 and T2
RP6 = R3 | R2
The Question:
RP2 = R3 | R4
RP6 = R3 | R2
