Calculating the resulting resistance
activee
Joined Jan 16, 2014
39
Hey I'm not sure how to do this, I'm actually blocked at R4.
I first thought I had to do like R4 and R5 weren't even there but I don't have the right answer.
I did : R1 + (1/(1/(R2+R6) +(1/(R3+R7))) but that's not right. I got 3600.
Could you help ? thanks
activee
Joined Jan 16, 2014
39
Do the current even go through R4 and R 5?
Try redrawing the circuit from the prospect of kirchoffs current law
Well there will be more current in R3 than in R2. Does that mean that there will be a ddp between the two ends of R4 ?
shteii01
Joined Feb 19, 2010
4,644
You will have to do Delta-to-T transformation.
R4 and R5 are the easy part. They are in parallel, so find equivalent resistance and replace R4 || R5 with their equivalent.
activee
Joined Jan 16, 2014
39
like this ? R2, R3 and R4 in delta to Y. Same with R5,6,7.
still not the good answer though
amilton542
Joined Nov 13, 2010
497
This breed of finding equivalent resistance gets tricky here.
Choose a voltage source of arbitrary amplitude and apply KCL and KVL to find the current through this source.
Your equivalent network resistance will be V divided by the current through this source.
The Electrician
Joined Oct 9, 2007
2,986
Replace R4 and R5 with a single 5000 ohm resistor; call it R45.
Now do a delta-wye (same as delta-T) transformation on R45, R6 and R7. DO NOT transform R2, R3 and R4.
I get 48700/17 which equals 2864.706
32,874
Your diagram in Post #5 is wrong. Look at the right hand transformation. Carefully label the three nodes of the delta circuit and then label the corresponding nodes of the wye circuit and ensure that they connect to the exact same nodes in the overall circuit that they did originally.
