I have a 3D printer that uses the Meanwell LRS-150-12 (150 Watt, 12V DC) power supply (Datasheet: http://www.mouser.com/ds/2/260/LRS-150-SPEC-806177.pdf) and I am installing a power socket and switch on the AC input side. The distance between the PSU and switch is only 8 inches but I wish to use the correct gauge of wire for both that connection and the actual power cord to the wall.
It looks like 18 gauge PSU style power cords are the most common while 14 gauge cords are very thick and harder to find. Would it be safe to use either 16 to 18 gauge wire in between the socket and switch along with an 18 gauge PSU cable?
I know that power in is roughly power out with some power in lost as heat but I would guess that the AC current is about 150W/120Vac = 1.2Amps (I am in the US) but I believe I need to know the power factor in order to calculate the real value. All of the circuits I have dealt with have been DC so the idea of RMS and AC power (and the power factor) are confusing to me.
