I have the following circuit attached. Including the problem and solution. for some reason, I either can't plot it in LTSpice correctly to verify the answer, or my answer is incorrect. Would someone help please?
For some reason I can't look at your schematic. Can you use a different file type to post it? Even Paint will create a viewable JPEG file.I have the following circuit attached. Including the problem and solution. for some reason, I either can't plot it in LTSpice correctly to verify the answer, or my answer is incorrect. Would someone help please?
by Jerry Twomey
