It should be obvious that the input is the input impedance of the transistor in parallel with its biasing resistors.It was not specified that the the two resistors was taken as parallel connection that produced the 149 ohms.
Impossible. The definition of the cutoff is when the output is 0.707 times (-3dB or half power) the input.I would like it to cut -off at 60 hz with a very low voltage drop across the C1.
We don't know what you are talking about.Maybe a 90% to 100% input transfer voltage from Rg2 to the total input of the transistor. I guess I can use another 220 nano capacitor in series with one the prods of my analogy meter to pick off the gain of the input signal at Vc ?
Your meter has a certain input resistance that can be calculated with an input coupling capacitor for a cutoff frequency.
