No, but you did when you stated, "Lines that have one and only one point in common are known as intersecting lines."Obviously they do, I thought you would know that, are you saying they don't.?
The fundamental relationship is work(W) = force(f) * distance(d). When calculating the amount of work done by a 'twisting' force (torque) we much consider the distance from the center of the force giving arise to the work done:Ah, so torque * motion = work. Got it.
Okay, so educate me. What is the meaning of these two lines crossing? Would they cross at this same rpm if you were someplace where power was measured in kilowatts and torque was measured in newton-meters? If not, would this particular rpm still have any significance whatsoever?@WBahn. This is not something that I made up. It is a well known fact that any internal combustion engine engineer, engine builder or hot rodder knows. And any dyno chart of any gasoline or diesel engine shows it. Eric gets it, sorry that you don't.
