Calculating frequency bin
ivyivyivy
Joined Jan 9, 2017
I have time series with 72 terms and frequency 1/12 (1 cycle/12 months) and it is explained here that the frequency bin for positive frequency is 72/12+1 (+1 is because of MATLAB's syntax). But on the other side there is formula where frequency bin is k=fs/N, where N is length of time series (72 in my case) and fs is frequency (1/12 in my case). When I use this formula I get 1/(72*12), which is different from the upper 72/12, what is my mistake here?
34,807
You are confusing your units.
Your x scale is years.
You are taking 12 samples each year. Hence your frequency is 12 samples/year.
34,807
Your record length = 72 samples, i.e. N/fs = 72/12 years
Your frequency spectrum bin = 1/(record length) = fs/N = 12/72 samples/year
ivyivyivy
Joined Jan 9, 2017
May I ask you is that mistake in tutorial? There is that positive frequency bin is 72/12, what is diferent from frequency spectrym bin which you wrote. I can't find what is mistake, but I see that something is different and unreachable for me.
34,807
I don't know what the tutorial did. I have not looked at it in detail.
The first point is 0 frequency.
The next bin is 12/72 = 0.16666... samples/year
Your Nyquist frequency = fs/2 = 6 samples/year
Hence the last bin would be (6 - 1/6) = 35/6 = 5.8333...
ivyivyivy
Joined Jan 9, 2017
Thanks on all answers. This is part of the tutorial which is of interest in this question and there is formulation that frequency bin is 72/12 and i still can't understand relation beetwen your answer and tutorial:
Determine the frequency bin in the discrete Fourier transform that corresponds to 1 cycle/12 months. Because the frequencies are spaced at 1/72 and the first bin corresponds to 0 frequency, the correct bin is 72/12+1. This is the frequency bin of the positive frequency.
