Calculating for a Gyrator Notch Filter
BarryBozeman
Joined Apr 1, 2016
41
Hi there -
I'm attempting to build my own calculator for a gyrator notch filter, but I don't know how the equation works exactly.
On the Elliot Sound Products website (http://sound.whsites.net/articles/gyrator-filters.htm), the equation is explained as :
f = 1 / ( 2 × π × √( L × C ))
I am uncertain, though, given the schematic, how to calculate for L, when there are no inductors. There is a step I'm missing.
Can anyone walk me through this equation? Thank you.
LvW
Joined Jun 13, 2013
2,038
The operational amplifier - together with R1,R2 and C1 form a so-called "active lossy inductor".
The input impedance of this part of the circuit is
Zin= sC1R1R2 + R1 +R2.
Hence, this active circuit simulates an inductor Ls=C1R1R2 iin series with a resistive loss (R1+R2).
As you know - a series resonant circuit Ls_Cs has a minimal impedance at w=wo.
Therefore, we can realize a (non-ideal) notch filter as shown in the diagram using an additional resistor Rs. Now, we have a voltage divider consisting of Rs and a lossy series resonant block.
LvW
Joined Jun 13, 2013
2,038
Dana - it is an 80-page paper.
It would be helpful if you would give some hints on which page the question is answered.
BarryBozeman
Joined Apr 1, 2016
41
I'm sorry, but I'm failing to understand something here. The goal, if I didn't manage to state it correctly: I'd like to make a simple equation, wehre if I enter values for R1, R2, C1, and C2, I can calculate the resonant frequency and the Q of a gyrator.
I'm not sure if I can get figure out how to get the value "L" (as used in "f = 1 / ( 2 × π × √( L × C ))") from the above information.
LvW
Joined Jun 13, 2013
2,038
Didn`t I gave you the equation for the active-L ?
Do you realize that a series connection of L-C has a minimum for a (well-known) resonant frequency?
What else do you need?
You were asking "how the equation works". I have tried to explain how the circuit works.
