Calculating Coupling Capacitor Values
RRRRSSSS
Joined Jun 16, 2023
128
Hi:
I am experimenting with an emitter-follower circuit. The input impedance is 14.236 KΩ
and the output impedance is 32 Ω. The corner frequency is 20 Hz. I have calculated the
input and output coupling capacitor values as follows.
C1 = 1 / (2 * π * fmin * Rin(total)) = 0.559 μF
C2 = 1 / (2 * π * fmin * Rout) = 249 μF
Do these values make sense?
Thanks for your input.
RS
BobTPH
Joined Jun 5, 2013
11,675
The output coupling capacitor needs to be based on the load impedance. Did you do that? I get 7.8uF using 1000 as the R.
Edited to add: Actually both resistors have an effect, but the the 1000 dominates.
AnalogKid
Joined Aug 1, 2013
12,291
Assuming you mean a 32 ohm load, such as an earphone, your math is correct. To build it with real-world parts, round up to the next available values. Unless you are trying to match a specific sonic profile, larger coupling caps rarely hurt anything.
A true 32 ohm output impedance is not a good idea. Modern headphones and earbuds are designed for amplifiers wht a low output impedance. Also, your circuit has an asymmetrical output impedance, meaning that the impedance when sourcing current into the load is difference from the impedance sinking current out of the load.
Note that for "flat" response down to some corner frequency, the response actually is 3 dB down at the corner freq. IOW, the output voltage will be only 70% of the "flat" value. One octave away it is down only 1 dB (89%). So if you want the amplifier to be "flat" down to 20 Hz, and if the two corner frequencies are 10 Hz, the response will be down 2 dB at 20 Hz, one dB per highpass filter.
ak
RRRRSSSS
Joined Jun 16, 2023
128
Just to clarify regarding a Common-Emitter Amplifier.
No External Load
Rload = RC
Zout = RC
With External Load(RL)
Rload = RC║RL
Zout = RC
And the ouput coupling capacitor value is calculated using Rload?
Is this correct?
RS
AnalogKid
Joined Aug 1, 2013
12,291
There is no RC on your schematic.
Separate from that - incorrect.
The output impedance of an emitter-follower circuit is not symmetrical. That is, it is a lower impedance when sourcing current through the emitter than when it is sinking current through Re. Most materials assume that the load impedance is much greater than Re, and does not affect the calculations. If this case, both the source and sink output impedances are considered equal.
https://inst.eecs.berkeley.edu/~ee105/sp08/lectures/lecture10_6.pdf
ak
Pedantic tidbit: BTW, the technical name for an emitter follower circuit is a common collector circuit.
RRRRSSSS
Joined Jun 16, 2023
128
ak
I am asking about a common-emitter amplifier. If my statement is incorrect then please
correct me. Thanks.
Audioguru again
Joined Oct 21, 2019
6,826
Your schematic shows an emitter-follower. A common emitter transistor is different with its output from the collector.
Since your emitter-follower has a 1k emitter resistor then its pull-down output is overloaded at high levels with your 1k load resistor.
I increased the load resistance then it works much better, even at 20Hz.
Here are my simulations:
AnalogKid
Joined Aug 1, 2013
12,291
The only schematic you have posted, and your very first sentence, are about "an emitter-follower circuit." If this is not what you intended, no problem. Please post a schematic of the circuit you want to discuss.
ak
