Calculating average current draw for a intermittently operating circuit
DieselPete
Joined Aug 20, 2023
5
I'm running a battery powered telemetry system which provides data at x (currently 15) minute intervals.
I have a level sensor powered by the telemetry system battery which is energized for 15 seconds per data period.
The sensor has a max current draw of 100 mA.
I'm trying to figure out the number to put in this box to get an accurate Battery Life Estimate.
I appreciate your help.
Link to telemetry system: https://www.signal-fire.com/wp-cont...0099-01-SignalFire-Ranger-Manual-Rev-1_10.pdf
Link to sensor: https://www.ssi-sensors.com/perch/r...al-fluid-trac-220-product-overview-dt-an8.pdf
schmitt trigger
Joined Jul 12, 2010
2,242
Even though the average current is quite low, the battery must be able to handle the peak current bursts, otherwise the battery won’t last.
Many moons ago, in another forum there was an almost identical question to which I provided an identical answer, which the TS chose to ignore and powered his project with coin batteries anyways, with predictable (poor) results.
Hope you don’t make the same mistake.
DieselPete
Joined Aug 20, 2023
5
It's running a 4 D cell lithium pack.
DieselPete
Joined Aug 20, 2023
5
UPDATE: After a precipitous fall from the original voltage of 3.67 VDC the battery has now stabilized at 3.53 VDC. I did lower the sensor on-time to 10 seconds as that was enough to get a reading.
Thanks to all for your input.
