I am writing data to EEPROM at 9600BR. I am using HyperTerminal to transfer characters. When i transfer 3 character at the same time, Its works but the problem arise when i try to transfer greater then 3 bytes at the same time. Therefore i've done calculation to see where the problem lies.
(The screen-shot of the Write Module in given below)
1) My MCU Freq = 4Mhz, Each instruction takes 4-cycles so write module have 13 instructions (see the screen-shot), instruction will take 13usec (13/1M) & Instruction time + EEPROM Write time(10ms) -->Approx 10.013ms.
2) 4 bytes should take around 40msec (13u*4).
3) I am using BR 9600 bits/sec; converting to byte will be 1200 bytes/sec(9600/8) means --> 1 byte will take approx 833usec (1/1200) to be on the bus.
I may be missing something...
Any help would be appreciated.
