C code for FFT of sine wave
t06afre
Joined May 11, 2009
5,934
Writing a DFT algorythm is easy, it's basically just 2 stupid loops, one inside the other. Depending on the length of your array it might be good enough to just write a DFT vi. FFT might be faster, but there's more coding, which in turn means more things to potentially go wrong. Also, it seems that the fastest FFT method depends on your dataset.
Each frequency component is the result of a dot product of the time-domain signal with the complex exponential at that frequency and is given by the following equation.
The DC component is the dot product of x(n) with [cos(0) – jsin(0)], or with 1.0.
The first bin, or frequency component, is the dot product of x(n) with cos(2πn/N) – jsin(2πn/N). Here, cos(2πn/N) is a single cycle of the cosine wave, and sin(2πn/N) is a single cycle of a sine wave.
In general, bin k is the dot product of x(n) with k cycles of the cosine wave for the real part of X(k) and the sine wave for the imaginary part of X(k).
This should also help http://en.wikipedia.org/wiki/Discrete_Fourier_transform
T.Jackson
Joined Nov 22, 2011
328
This is in regards to using an MCU with a DAC to produce a sine wave?
I personally would be hard coding into an array what I calculated with pen and paper using: SINǾ (theto) x VP
This data can be manipulated in software to make changes.
codehead
Joined Nov 28, 2011
57
Hi i need the code in assemble language or C code for finding the FFT of Sine wave..Please help me
You'd get better help with a better explanation of what you need. You don't even say what assembly language, for instance. Also, it would help to know the purpose—are you really trying to just get the FFT of only a sine wave? There are plenty of FFTs in C on the web.
codehead
Joined Nov 28, 2011
57
What is FFT?
Fast Fourier Transform. It's a DFT (Discrete Fourier Transform, as in discrete time—useful for processing samples in the digital domain in other words), that has been optimized by eliminating some redundant calculations so that as the number of samples doubles, the required calculations don't (they are related to the log of that number, so it's a huge win for longer transforms).
The forward transform moves time domain samples to the frequency domain (converts a series of samples equally spaced in time to frequency values), and the inverse transform goes the other direction.
It works like this:
http://www.earlevel.com/main/2002/08/31/a-gentle-introduction-to-the-fft/
For anyone not getting the time/frequency domain references, this page show how you can set the frequency domain values with sliders (each corresponds to a sine wave at 1x, 2x, 3x...) and the time domain view of the waveform that corresponds to it:
http://www.earlevel.com/main/1996/11/14/the-fourier-series/
codehead
Joined Nov 28, 2011
57
What would be some practical applications for FFT?
A few examples:
• You could generate arbitrary cyclic waveforms (similar to the Fourier demonstration with sliders that I showed you). It's much faster to use an FFT to make that waveform that to similarly build a waveform by calculating and adding up harmonic sine waves. You could make a musical instrument with oscillators made like this, and even morph between them for dynamic sounds.
• You could make a spectrum analyzer—converting incoming samples to a harmonic spectrum for viewing.
• Some things are more efficient to do in the frequency domain. For instance, (circular) convolution in the time domain is multiplication in the frequency domain. If you're sampling audio at 48 kHz and want to convolve it with a 6-second impulse response of a cathedral for an awesome reverb, that's 288,000 multiplies/adds for each input sample, or nearly 14 billion MACs a second—twice for stereo—and times any additional overhead for the loop. Instead, you can convert the input samples to the frequency domain, do the convolutions as multiplies (other overhead involved as well, but still a huge win), and convert it back to the time domain to play out on your speakers.n
Note that a DFT/FFT is just a snapshot—it's focused on taking apart one cycle into its component harmonics (Fourier discovered this while looking at how heat propagated through and iron ring!). The real world doesn't line itself up nicely in cycles that complete over a number of sample known in advance, and different sounds with difference wave lengths can overlap. Fortunately, you can morph a stream of these snapshots, overlapping, and convert arbitrary sound between time and frequency in sort of the same way that we watch fluid motion from a series of still pictures in movies.
joeyd999
Joined Jun 6, 2011
6,456
So there are no real 'practical' applications that would interest a normal person then?
I use FFT quite frequently for noise analysis. Lots of times, noise an a signal looks "random", but passing it through an FFT often shows discrete peaks that correspond to noise sources in other parts of the system. This assists in making changes that attenuate interference from those parts of the system.
T.Jackson
Joined Nov 22, 2011
328
LOL I said for 'normal' people.
You know the other 99% of the population who live normal lives?
codehead
Joined Nov 28, 2011
57
ROFL—I take it you're joking. The FFT is one of the most widely used numerical algorithms on the planet. It's used in image processing (ever seen Photoshop?) music and recording gear of many types, video, electronics test gear.
But it depends on what you mean by "normal". Certainly, "normal" (if you mean average) people have no interest in this website.
codehead
Joined Nov 28, 2011
57
BTW, I just did a search of the forums here and came up with 1,418 hits for "FFT"...for the web, google comes up with 25,600,000...
T.Jackson
Joined Nov 22, 2011
328
You could not do MRI scans without FFT.
Well at least that's something.
Magnetic Resonance Imagining (that much is true I do have a bit of an interest in medicine) -- we can diagnose with almost 100% certainty, but cannot cure even 1% of cancer with any real absolute certainty.
Most things show up on a CT scan that are within 1mm. In Australia, we don't bother with MRI much, because the benefits don't out weigh the risks and the associated costs when a CT scan can usually suffice.
35,159
CT scans uses X-ray radiation. MRI scans do not use ionizing radiation.
T.Jackson
Joined Nov 22, 2011
328
If you have ever done any metal work in your life, then you are at potential risk with having some complications after having an MRI scan.
An MRI scan requires a more qualified person to operate, and it can take an hour to do an abdominal scan as opposed to a few mintutes for a CT with contrast.
T.Jackson
Joined Nov 22, 2011
328
Either way, say no to anything besides painkillers if you ever get cancer.
The scans are pointless, unless you are willing to consent to prolonged misery.
