So I probe every pin that is "tied" to the buss line using a current tracer, which ever pin has the higher current is the bad IC chip?If you have a bus contention fault, you use the current tracer to trace back to the drivers with high currents. Only one of them should be trying to drive the bus, so the others are at fault. Either the at-fault driver is stuck or something upstream is defective.
