This is on my BM869 DMM that I damaged the VAC section on, I'm just getting into the RMS-DC converter section. It's part of a divider network on a op-amp +. I'm still mapping the main PCB, the upper PCB also contacts the rotary SW, oh boy...
Here's a pic, it's labeled in the PCB as a resistor, going into the brains of the DMM. To me it doesn't look burnt, and looks glossy at an angle, and with a texture similar to some caps. Also from side on, it looks just like the other SMD resistors, same white stripe near the top, not burnt looking. It takes a little while to settle to 65k, I should pull it anyways, but I it's not labeled anyways, if it's a fusable resistor or some other protective resistor, IDK ?.
