Building a current source with LM234
Lupon
Joined Jan 1, 2020
Hello everyone.
I want to build a current source for low currents, 1-5mA. I've searched for something easy and found the LM234. In his datasheet there are an application to build an independent temperature current source (pg 6). I've simulated in Pspice with this model for the LM334, and work. (see atached images)
So i've decided to try implement. (see atached images)
VCC it's 5V.
But when i've mounted in a protoboard, don't work. If i change the load, current across the load (potentiometer) change. Anyone know what i misunderstanding?
AlbertHall
Joined Jun 4, 2014
12,653
As you increase the load resistance you will eventually reach the point where there isn't enough voltage left for the current source to work properly.
What is the supply voltage?
Lupon
Joined Jan 1, 2020
Resistance ranges from 0 to 2k. Voltage is 5,2 volts approx, taken from a ATX PSU. In addition i tried 5 volts from Arduino Uno. In both cases similar result.
There isn't linear zone. If i change resistance with potentiometer, change intensity. With very low values i get even more than 100mA. Attach a graph with some random values that i taken:
