The operation of buck converter or any converter is clear if the load is resistive. However, when the load is as a voltage source or current source as a battery. I think I struggle in understanding the limitations of the buck converter operations. in the case of the input source is a solar panel, the relationship between the output and input voltages is by the duty cycle; Vbattery = D*Vpv. Now if the I want to use MPPT, I can change the duty cycle in increase if the power increases and vice versa under the condition that output resistance is less the input resistance . Now by changing the duty cycle, I know the Vpv will change because the buck converter changes the impedance seen from the solar panel by changing the solar panel. Now in changing the duty cycle, does the output voltage changes also? or it is just clipped to V Battery voltage that is in Bulk charge. We also know that V battery voltage is increasing as the SOC increases, hence its impedance changes. Also, how can the equations of the buck converter if the buck is connected to a battery. Note that there is one loop that is adjusting the duty cycle based on the sensing of voltage and current of PV and adjust it for MPPT,
Let summarize it in this:
Let's say the battery is in bulk stage and I want to charge it with MPP and let's also consider Temperature and irradiance are constant , we increase the current only by varying the duty cycle and the output voltage is clamped to the battery voltage. During the Bulk stage, the battery voltage increases and we cannot regulate this output voltage. What the effect of this increase in voltage in the MPPT operation and the DC-DC converter in general?
Can we also set a constant duty cycle that regulate the output voltage after bulk stage assuming the input is constant ?
lets now ignore the safety (for max current ) and output voltage regulation after bulk stage for now.
