BT Speaker, "Charge and Play"- functionality.
SuperStian
Joined Jul 30, 2017
Hi all,
So I was at a festival last weekend and thought to my self when our overpriced bluetooth speaker died from battery failure that could make it better my self. Turns out, when I sobered up, it was a bit more difficult than I thought.
I found a BT-Amp on eBay (and amazon) called TDA7492P. It is quite awesome from the looks of it.
I have a couple of old speakers:
Impedance: 8Ohms
Input Power: 65Watts
Peak: 100W
I have found this power bank:
TalentCell
12V/6000mAh
Now, this power bank looks promising to my very noob eyes.
Question:
I want to be able to charge the battery of my wonderful bluetooth speaker and listen to music at the same time.
How can I achieve this?
1. Charge the battery with only one connected cable to the case.
2. Use battery as power source
3. Use wall power as source
Please have a look at the attachment :)
Can someone with experience and the proper knowhow help me out? Please!
Dodgydave
Joined Jun 22, 2012
11,395
Your battery is a Li-on type ,using 18650 cells, looking at various videos on youtube, the battery comes with a charger and Y lead for using whilst charging which means the charger will be giving out more current to power the load and battery at the same time.
SuperStian
Joined Jul 30, 2017
Alright, so a Y-cable allows me to charge the battery (slowly) and use the speaker at the same time. That is what I'm looking for. Now, how do I actually connect it all up?
+ and - goes from the battery to the amplifier.
+ and - goes from the wall power through the AC/DC converter and to the battery
+ goes from the AC/DC converter "around" the battery and to the amp
- goes directly to the battery from the amp.
See image below.
I know this is a lot to ask, but would it be possible for one of you with the brains to do so draw up the connections? Thank you so much in advance!
Dodgydave
Joined Jun 22, 2012
11,395
All the +/- connections are in parallel together. the charger feeds both the battery and the speaker, when you unplug the charger the battery takes over.
