My daughters hoverboard died so I salvaged the motors. I am trying to use the motors and battery to power a toy 4-wheeler for my twin 3 year olds. I purchased a controller and throttle and have it wired up but cannot get the motor to turn. See attached schematic. When I flip the switch on the throttle the battery display LCD turns on and shows the voltage which matches what I read with my meter. When I check voltage between the Red and Black throttle wires it reads about 5 volts. When I check between green and black it modulates depending on how much throttle I give it between 0 and 5. When I measure the voltage across the hall sensors I get 0 or 5 volts depending on the motor shaft rotation. From what I can tell the controller seems to be working however I cannot get a voltage on any of the three motor power wires and the motor will not spin. I have tried plugging the autolearn wires from the controller together and then to the autolearn wire on the motor. I then disconnected the autolearns and tried the 36 combinations of wire and hall sensors and still have not been able to get it to turn.
I can't read Chinese but the limited information that came with the controller said that the door lock must be connected or there would be no electricity. Since I can see the power through the throttle and know the throttle output is working I think I have it wired correctly. Here are links to the purchased parts:
https://www.banggood.com/36-48V-350...-1194278.html?rmmds=category&cur_warehouse=CN
https://www.banggood.com/36V48V60V7...5.html?rmmds=category&ID=229&cur_warehouse=CN
