Broken circuit board from kettle
Wolframe
Joined Jul 29, 2024
I have a kettle that seems to have gotten water inside it, causing the circuit board to fry. I've replaced a fuse and am now trying to identify the broken components so I can hopefully fix it. I'm quite a newbie with circuitry and don't really know what I'm doing. Can anyone spot anything obviously broken? The missing green part of the board seems problematic, but I'm not sure. Is this board completely beyond repair?
tonyStewart
Joined May 8, 2012
239
The milled green slots are the air gaps for >3 kV insulation.
I see nothing obvious in the photo that shows heat damage to blow a fuse. But then that doesn't mean it is OK.
How about the other side?
Wolframe
Joined Jul 29, 2024
There doesn't seem to be much damage on the other side but I could be wrong. 1000006811.jpg
