Bridge rectifier circuit has negative DC Bias
J. S. Padmaja
Joined Apr 28, 2017
5
I was testing a bridge rectifier using 4 germanium diodes (1N60). The output should look like a sine squared plot with only positive voltage but I am getting the same shape but with average voltage zero (basically the final waveform has a negative DC bias). This is highly undesirable for my project.
PS: I tried Schottky diodes with same issue and I cannot use silicon diodes or bridge rectifier ICs. This is application specific so I cannot use batteries or clampers either.
Can someone please suggest a solution?
Thanks!
38,767
Why do many newbies seem to think we are clairvoyant? :confused:
How can we answer your question when we don't know what you exact circuit is, or the what the input and output waveforms look like?
The solution, based upon the information you have given, is to configure the bridge so it works. :rolleyes:
J. S. Padmaja
Joined Apr 28, 2017
5
Could you be specific about what more information you need? I gave all the info I could think of. (I do not have much experience with circuits)
AnalogKid
Joined Aug 1, 2013
12,265
A schematic diagram showing all components and connections, with a value and reference designator for each component.
Pretty please with sugar on top.
ak
J. S. Padmaja
Joined Apr 28, 2017
5
Hello all,
Thank you for your replies.
I couldn't get to the lab until now so I decided to send a pic with the connections and the output I saw on the scope. I hope that is clear enough. Apologies if it isn't. I gave the values of components and the place where I have connected the input and the scope probes.
Thank you!
