I am connecting 3 phase 400v power supplies to some woodworking machinery with multi strand SY cables. I would like to use bootlace ferrule connectors for the wire ends before they are secured in screw terminals. I have seen a kit that (on the face of it) looks suitable here.
However the ferrule material or amp capacity are not noted. I then viewed similar ferrules on RS, and TLC electrical which again were not rated. I have seen that Farnell do rate their ferrules and have amp ratings but are significantly more expensive)
Commonly these terminals are tin plated copper. Is there a significant risk in using generic cheap ferrules? Would metal type / conductivity pose a risk of overheating? Or does the fact they are so thin negate this being an issue? Previously I have used many generic crimp connectors without a second thought. I would like to have an understanding so I can better assess what I'm buying and using.
Jess
(A woodworking guy)
Jess
(A woodworking guy)
