Boolean simplification....kind of stuck on a certain form of expression
RyanKim
Joined Sep 18, 2011
37
Hi guys I was wondering if anyone could take a look at 2 expressions I have that I can't seem to simplify. Im basically one step away from the answer at both junctures but I can't logically apply a law that I know how to use to get the answer.
The first equation that I've pretty much solved has boiled down to this:
1.) A!B! + B!C + A! + B! + C! (Where ! means not. E.g A! = A not)
Final answer suppose to be A! + B! + C!
and secondly
2.) Q! + R! + S! + R!S + QR!R!
Final Answer suppose to be Q! + R! + S!
I cant seem to figure out what to do next. Im not aware of any law that can be applied here...though I do notice in both expressions B! and R! may have something to do with it respectively?
Thanks!
t_n_k
Joined Mar 6, 2009
5,455
I don't think your second question partial solution is correct - if that's the given solution. Can you post the original question?
justtrying
Joined Mar 9, 2011
439
for the second part try factoring out R!
Q!+S!+R!(1+S+QR!) =
is there any law you can apply now? think of 1+X = X
p.s. even before grouping, you can simplify R!R! - recall XX = X
RyanKim
Joined Sep 18, 2011
37
Ahh thanks T_N_K I think I got the first bit...(X + 1) = 1. For the second part perhaps I should have added brackets but that was the given solution by my prof.
Q! + R! + S! + (R!S + QR!R!)
So I guess R!R! = R! therefore (R!S + QR!) = R! ? Then Q! + R! + S! + (R!) = Q! + R! + S! Since ( X + X = X)?
f = ( (QRS) (R + ( S + (QR!) )! )!
t_n_k
Joined Mar 6, 2009
5,455
A computer generated minimization gives me the solution
X = not Q or not R or not S or not RS;
which doesn't match up with the solution you have.
justtrying
Joined Mar 9, 2011
439
you can also do this:
!(QRS(R+!(S+Q(!R))) = !(QRS(R+!S(!Q+R)) = !(QRS(R+!S!Q+!SR) = !(QRS)
if you are wondering about how I got the final answer, check out basic multiplication rules ;)
justtrying
Joined Mar 9, 2011
439
not quite...
(R!S + QR!) cannot equal R! but Q!+R!+S!+R!S+QR! is valid. Then what happens if you factor out R! (see earlier post)
