Boolean algebra simplification
digesh9870
Joined Nov 8, 2016
11
Can someone help me. I am still a beginner and hence this minor doubt. We know the basic boolean algebra rule that 1 + X = 1. Does this also hold good for 1 + XY and 1 + XY' ? Is the following simplification right ?
XY' (Z + YZ') + Z
= XY'Z + XY'YZ' + Z
= XY'Z + Z
= Z (XY' + 1)
WBahn
Joined Mar 31, 2012
33,365
Assumptions: 1 = Logical True; + = Boolean OR operator
Yes, (True) OR'ed with (Anything) is (True).
XY' (Z + YZ') + Z
= XY'Z + XY'YZ' + Z
= XY'Z + Z
= Z (XY' + 1)
Yes, as far as you've taken it. Now you just need to finish it off.
You want to start verifying the correctness of your work from the result you get. This is almost always possible in most fields of engineering.
In this case you have:
XY' (Z + YZ') + Z
And your end result (once you finish) is that this is equivalent to Z. So that means that this expression must be True whenever Z is True and it must be False whenever Z if False. So check those two conditions and see if they hold.
digesh9870
Joined Nov 8, 2016
11
XY' (Z + YZ') + Z
Thank you . Yes, I am talking about boolean algebra . I was curious to know that 1 + X = 1 also holds good for 1 + XY = 1 & 1 + XY' = 1. So I tried solving the aforementioned expression. As you said, the final answer (simplified form) would just be Z. I checked this using truth table and XY'(Z+YZ') + Z is nothing but Z only. Please correct me if I am wrong . Thank you both for your time.
WBahn
Joined Mar 31, 2012
33,365
You are correct. Clearly if Z is True then the expression is True. Now we just need to see if there is any way for the expression to be True if Z is False. If Z is False the expression collapses to XYY' and regardless of the value of Y, either Y or Y' is False.
