Books for a hobbyist
BamaFan
Joined Sep 2, 2016
6
It has been a long time since I studied electronics. I hold an Associate of Electronics Technology degree, 1966, but I am a little rusty. I am quite familiar with basic AC & DC theory, wiring and power, and test intruments, so i don't need a book for beginners. However, we didn't study much electromechanical theory back then as I remember. I want to learn how to design, breadboard, test, and implement circuits for controlling motors, valves, pumps, etc. for use in an automotive environment.
Can anyone recommend any good books for me.
ian field
Joined Oct 27, 2012
6,536
There's probably an electronics for dummies, and one ............for the evil genius books. They're quite modern, but a bit superficial IMO.
You'd need to elaborate a bit on where you want to go with this - the range to choose from is staggering.
BamaFan
Joined Sep 2, 2016
6
I have never liked the books for dummies as they seem too simplistic. I am looking for a book with some sample projects, ranging from relatively simple to complex. I know and hopefully remember enough about semiconductor theory to figure out what is happening in a circuit. As an example, I have a motorhome in which I would like to make some modifications to control air valves, motors, and timers. Thanks.
AlbertHall
Joined Jun 4, 2014
12,629
I learnt an awful lot of my electronics from books in Darlington (UK) library, fabulous. Now there is so much information online (including books) I suspect it is close to making technical books obsolete. Google automotive control circuitry.
ian field
Joined Oct 27, 2012
6,536
There's tons of books on archive.org - if you know what you're looking for....................
GopherT
Joined Nov 23, 2012
8,009
Go to your public library and get a stack for a week.
GopherT
Joined Nov 23, 2012
8,009
Or, you could just tell us what you want and we will start guiding you to some search terms or guide you to a better solution.
recklessrog
Joined May 23, 2013
985
Even though i have a degree and spent most of my life involved in electronics, There are two little reference books I keep with me right on the bench. They have proved invaluable over the years! Published by Bernard Babani and written by F.A.Wilson. they are:-
1, Practical Electronics Calculations and Formulae BP53.
2, Further Practical Electronics and Formulae BP144.
Unfortunately now out of print, but they are often listed on Amazon for a few pounds each.
Very well written, and not overly complex. I use them as memory joggers when the old brain has a freeze up :)
KL7AJ
Joined Nov 4, 2008
2,229
If you can find a copy of Electronic Communications, by R.L. Shrader, grab it. (No, you can't have mine). Any edition of the ARRL Handbook is great, too.
BamaFan
Joined Sep 2, 2016
6
Thanks Guys.
I am taking all of this advice to heart and will seriously consider all of these sources. I will also need advice on buying test equipment once I get started. For example, I will need an inexpensive standalone ammeter for in-circuit testing, but don't know where to shop for such an instrument. Amazon.com, ebay? I doubt it.
We are traveling right now, so I won't be able to do much for a while.
dl324
Joined Mar 30, 2015
18,363
Since you're just starting out, I wouldn't spend more then $20 on a DVM. Don't become dependent on measuring current with a meter. The meter resistance can affect readings. Measuring the voltage drop across a resistor that's already in the circuit is a better method, or insert a small resistance for that purpose.
If you're in the US, Harbor Freight has coupons for a free DVM with any purchase. Not the best meter, but you can't really complain if it's free. I have several so I can have one in my car, one in my tool bag, etc. I use a better meter for circuits, but they'll do in a pinch.
