blown fuse indicator
magnuskarlson33
Joined Apr 12, 2023
16
So for a project i need a bit of help ,so i have blade at the start of my pcb ,the board is powered 24v
and, I need a circuit in which led is not glowing when fuse is intact and only glows when fuse is blown
please help me with this
magnuskarlson33
Joined Apr 12, 2023
16
also when is fuse is blown the load will be completely disconnected from power source
MaxHeadRoom
Joined Jul 18, 2013
30,817
Just connect a LED with suitable resistor in series. Wire the two across the two fuse terminals.
The current should be enough to light the LED without significant current carrying capability
BobTPH
Joined Jun 5, 2013
11,659
Not if you put an LED + resistor across it as two of us have suggested. The current will actually flow through the LED and through the load, but it will be a very small current that will not power the load.
Ever seen an old light switch that lights up when the switch is off? That works the same way.
MaxHeadRoom
Joined Jul 18, 2013
30,817
I don't see any reference to AC ??
Link ??
WERE it AC, then a simple 24v Neon across the fuse would suffice. :rolleyes:
28,371
They are all over the place, in many sources. :confused:
Surely the OP knows whether it is AC or DC ??
Why does a DC pilot light have two black insulated leads??? My 120 volt AC neon devices have 2 black insulated leads, my DC LED pilot lights al have one red lead and one black lead.
Also, the TS asks about "An LED glowing" to indicate a failed fuse. So AC or DC my suggestion works. And the devices in the photo are not neon, but rather LEDs. I have seen them, we had a drawer full at one company. GREEN lenses with RED LRDs. They were not at all effective.
