blinking LED project
Maria 1990
Joined Oct 30, 2017
If your function generator has a 50 ohm output resistance, it can drive an LED directly.
You can use a transistor, if you still want to.
Hey. I saw the circuit you uploaded. I also want to make an LED flash only by ussing a generator ? Is it possible ? If I try only the first part of the image you uploaded can I achieve that ?
Do I need a power supply ??
Thank you very much for your answer .
Hyjacking someone elses thread is not allowed, Now you have a thread of your own.
This was split from
https://forum.allaboutcircuits.com/threads/blinking-led-project.76868/#post-1195148
wayneh
Joined Sep 9, 2010
18,104
I also want to make an LED flash only by ussing a generator ? Is it possible ? ...
An LED is versatile but is easily damaged by too much current. So in most applications there are other components to prevent excessive current. It could be as simple as using a battery with so little capacity that it cannot overpower the LED. It could be a resistor in series with the LED.
The current-limiting circuitry you need depends on the power supply you want to use.
Wendy
Joined Mar 24, 2008
23,798
If you want I could draw a schematic I think migh work?
This ought to do it I thought about putting a large capaxitor on the input lin because any DC On the signal source will stop the circuit from working. Q1 is not critical It can b a TIP100 or similar.
dl324
Joined Mar 30, 2015
18,326
If the signal generator can provide enough current, you only need to add a resistor.
But signal generators aren't usually used in this manner. It's more common for a circuit to have it's own power source and the signal generator provides input to a fairly high impedance, or a matched impedance (e.g. 50 ohms).
