Bit Incrementor
Yuesford
Joined Sep 5, 2017
Hello to all! I'm currently making a schematic diagram of a 3 bit binary incrementor and is not sure if it is a incrementor. (using a switch)
If i input:
0 0 0 = 0 0 0
1 0 0 = 1 0 1
1 1 0 = 1 1 1
1 1 1 = 1 0 0 0
It's like the draft adds one bit on my input
Until i saw a video where every time he press a button, a bit increments 1 bit. 000 -> 001 -> 010 -> 011 -> 100 -> ... -> 111
and i want to change my current draft into this and currently using 74xx IC? Can someone enlighten me if these IC can do these?
Link:
34,815
What you are trying to build is called a binary counter.
You can do this using what is called a t-type flip-flop or you can build what is known as a time-state machine.
You will need to debounce your push-button.
Yuesford
Joined Sep 5, 2017
I see, but my first draft was a binary incrementor am i right?
Yuesford
Joined Sep 5, 2017
Among others the 74192 SYNCHRONOUS 4-BIT UP/DOWN COUNTERS (DUAL CLOCK WITH CLEAR) comes to mind. Using a push button you can either increment (count up) or decrement (count down) the count. The push button(s) serve as the clock and you can count to N and reset where N is your choice. You can also build a binary counter using discreet components but a single chip like the 74192 is a simpler solution.
Ron
What's the difference between a counter and bit incrementer? Things got mixed out.
Reloadron
Joined Jan 15, 2015
7,890
Depends on the counter. Some counters like the 74HC4017; 74HCT4017 Johnson decade counter with 10 decoded outputs are decade counters with a decimal output. Some counters only increment with incoming clock pulses and some will decrement. Since you mentioned binary I suggested an Up / Down counter with a binary output. A simple 4 bit counter can be built just using a few flip flops like the CD4013 D flip flop as an example. CD4013B CMOS Dual D-Type Flip-Flop. Here is another example using the term bit counter. 74HC163 is a bit counter which outputs in binary.
Ron
34,815
Depends. Semantics maybe.
A binary counter can be considered to be a sequential circuit or a time-state machine, i.e. it assumes a new state following a clock signal.
A bit incrementer can be considered to be a combinational circuit, where the 4-bit output is a static function dependent on the static logic level of 5 inputs.
DickCappels
Joined Aug 21, 2008
10,661
That does not look much like a logic chip, but it does look a lot like a microcontroller.
1. Get a microcontroller
2. Connect the LEDs and switches
3. Write your code to get the function you desire, including button debouncing.
K Homework Help 6
Similar threads
4-bit Incrementor Circuit
