binary to 7-segment display
ShahJA
Joined Dec 30, 2023
5
Is this for schoolwork?
Hello, sorry for the late reply, i got lost trying to find this as well. And to answer your question, it's for one of the CEP's given to us in the semester, schoolwork in a sense yes. Unfortunately, it's due in two days and I am unable to understand the solution as well. So any advice is appreciated. I just need to display the output of an 8-bit unsigned multiplier.
And, as to why it is late, because it was given just in the last week as well.
In short, Respectable senior, any help on how to convert this binary to decimal and finally to a seven segment display. And then I can move n towards the remaining daunting CEPs.
Yours Sincerely
Shah Jan
dl324
Joined Mar 30, 2015
18,472
Are you simulating this? Are you supposed to learn how to do it using the double dabble algorithm?
The 74185 datasheet will give you some clues how to cascade logic that implements double dabble.
ShahJA
Joined Dec 30, 2023
5
No, not exactly, but now that I look at the datasheet it seems to be very much useful. I have Outputs S0-S15, which are the results of multiplication of any two 8-bit numbers. This multiplication is unsigned and uses 7483, a FA ICs and a half adder circuit made using 7486 and 7408. The display I get can be fed into a 7-segement display directly, but it overflows, after 0-9 and then cannot display 10-15.
ShahJA
Joined Dec 30, 2023
5
My question along with my thanks, senior is can I directly use this IC.
I am simulating all this in Proteus.
Actually, this is the problem I'm facing, how do I connect the outputs even if I use a similar IC. What I have is a 16 bit output essentially that is not displaying correctly.
Here is what I have made, its messy and not that great, but if you just want to get an idea about the question
And it contains the solution one of the other respectable persons made.
dl324
Joined Mar 30, 2015
18,472
74185 is no longer available.
Proteus has a symbol for 74185, but it doesn't work for simulations.
You can implement a 4 bit double dabble with about 18 gates. Information is readily available on the internet.
I read this once and believe it's correct: https://en.wikipedia.org/wiki/Double_dabble
Fortunately for you, 2 days is enough time to do it.
