Bigger generator...
Externet
Joined Nov 29, 2005
2,676
Hello.
A 5 horsepower gasoline engine runs a 120VAC - 2500 Watt generator, 3600 rpm, powering a 1500 Watt tool load. All fine.
The generator self-destructed with its own shrapnel from a foreign object inside the unit.
If a 5000 Watt generator is coupled instead as replacement, on same engine, same rpm... Will it perform normally on same 1500 W load ?
If the electric load is increased to 3000 Watts, the engine will not be capable, right ? And the generator will not be overstressed, right ?
28,272
Certainly the higher rated generator will not suffer overloading when it's ratings are not exceeded. BUT the engine may suffer overloading. AND it is not likely, if the generator is directly coupled, that a higher rated generator will be a bolt-on replacement. BUT it might be.
liaifat85
Joined Sep 12, 2023
200
The key constraint in this setup is the engine’s power, not the generator’s capacity. A 3000 W load requires about 4 HP of mechanical power (considering generator efficiency of ~85-90%). The 5 HP engine may handle it at the limit but likely not sustainably, especially if additional losses (like friction or heat) are considered. The engine can overheat or stall if pushed beyond its capabilities for an extended period.
