Hi, managed to make DIY auxiliary lights with info shared by helpful people on this website. Stuck at the last leg, so need some help.
I have made a circuit with 120W led lights running on a 12V 15amp wiring harness. Most push button switches use a 12vdc 50mA spec. Is this the right spec switch I should be using or a) do I need to create a resistor circuit around it or b) use a different spec switch. All help is sincerely appreciated.
