Baxi duo tec 24 combi make hotter water temperature.
Dodgydave
Joined Jun 22, 2012
11,395
Anybody know how to modify the factory set Hot water temperature from 60C to say 80C, it's set from 20 to 60C, is there a way to alter the user threshold voltage, which is by rotary potentiometer..the one on the right,,,ideally i need the circuit diagram, otherwise its re-engineer time!
The central heating temperature is factory set upto 80C, that's fine,.
PCB num
5121862
DickCappels
Joined Aug 21, 2008
10,662
Not really adjustable on my heaters, other than to disconnect one of the elements -that only changes the wattage). What kind of heater do you have.
